RobWNY's avatar
RobWNY
Goodyear Endurance Tire Pressure
Recently, I had 4 E rated Goodyear Endurance tires mounted on my 5th Wheel to replace the less than stellar Castle Rock Chinese tires that were on my camper originally. My EEZ TPMS showed Three tires to be at 77 PSI and One tire to be at 78 PSI when I left on my recent camping trip. I noticed that after about 15 minutes at highway speed (65mph) the PSI increased 10 PSI in the Three tires so they were at 87 PSI and 12 PSI in the fourth tire to make it 90 PSI. The tires only increased in temperature 6 degrees in that time span. The PSI and temperature readings remained at these levels for the duration of my 3.5 hour trip. Does anyone know if running the tires at these PSI levels is safe or should I back down the cold PSI a little so they don't go too far over the 80 PSI cold maximum marked on the tires?
