Doc Rose wrote:
Just starting out full time RV living. I have a 2015 Ram turbo diesel 6.7 with a Gooseneck hitch built in. I'm purchasing a toy hauler under 15,000lbs dry. I'd like to use the Gooseneck,pros/cons/ suggestions?
I'm with the others, gooseneck -to- pin box adapters aren't a great idea....especially since you're at 15K lbs dry. That's a pretty heavy 5er.
So does your truck have the Ram Gooseneck Prep package or is it an aftermarket gooseneck? If it's aftermarket you could use the B&W Companion hitch with the gooseneck as your center attachment point.
Another option is to install the
OEM RAM 5th wheel prep kit and get a hitch that fits in the pucks.
KJ
