- Grit_dogNavigatorDeet method is interesting. Never thought of it, but I know it sure eats plastic!
Great detailers truck! - 2012ColemanExplorer III used to use those kits that required multiple steps, including taping off the area, but found this product which works just as well. The lenses do fog up again, but this stuff takes minutes to use.
- austinjennaExplorerHad my daughters cars headlights done at Sams club. I think they charge like 25.00 and guarantee them for a few years. Cant beat the price and they still look good.
- ralphnjoannExplorerI just tried the "Deet" method using Off which is 25% Deet. It worked like a charm. I sprayed part of a folded up paper shop towel, wiped the lens, resprayed on another part of the towel and wiped again, then did the same thing for a third time. I washed it, then used a foam pad in a drill to buff with PlasticX. I washed it a second time, and then waxed it with Meguiars. More time and work might have made it look new, but I'm more than happy with the results.
- Mandalay_ParrExplorer
subcamper wrote:
Mandalay Parr wrote:
I checked on replacing them but $400 each so I passed on that. In my case I would have had to purchase the whole light assembly not just the lens.
Have you tried rockauto.com?
I replaced the headlight assemblies on several cars that were around 10 years old and I paid about $28-45 for each headlight assembly.
Yes, they are Chinese clones of the OEM units and are not as well built, but they have been working fine for years.
Steve
Thanks Steve.
Jerry - fj12ryderExplorer IIIHeck, I'd be happy if they just went back to glass lenses. Everyone knows the downside of plastic lenses, and they just keep putting them out. Talk about ignoring what people complain about.
- bobsallyhExplorer III have used Turtle Wax Kit (totally worthless), 3M Kit (better but not great, Toothpaste with grit (did better than the prior two),Brasso (which worked the best). Just give me back my sealed beams! I read an article a couple of months ago how bad the headlights are on the newer vehicles. The worst rated, some high-end BMW.
- LBL_1206Explorer
Xflyhighx wrote:
I was in the car business for a while. My detail shop used to use bug spray with over 30 deat and it used to look good. Don't know how long it lasts, but the price is right. The deat does something to the plastic. I didn't believe it neither until I saw it done. He used a micro cloth to polish it.
yep, me too. I have been using this same technique for a long time. two of my vehicles are always parked outside and the summer sun takes its' toll on those plastic lens. it's inexpensive,always available,less work producing the same results, multi-use-keeping the bugs off you while you polish the lens, and it works. - PadlinExplorerI've done it a couple times, wet sand with something like 2000, think I started with 600 and worked my way down. Buffed with compound (electric buffer), then applied wax. Came out crystal clear.
There are Utube videos on it if you look. - StraboExplorerRecently had our trucks headlights done professionally, wet sanded, waxed, buffed. Much nicer, but they are crystalizing, I can see it.
I did the lenses because I just had a shop install the best bulbs I have ever seen, LED's. Bui!T in heatsinks, plug and play on our F350.
AMAZING!!!!! Even have hi/low beam and I did the driving lights.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 22, 2025
