Dec-20-2019 05:47 PM
Dec-22-2019 04:07 PM
obgraham wrote:
I think a heated mattress pad comes as close to ecstasy on Earth as you can get! We use one at home, and now while snowbirding in chilly Arizona I am using the one we had in the MoHo. Fantastic device. Put it under the regular mattress pad to eliminate those little lumps from the wires.
The MoHo had a sleepnumber, which to me was just a glorified air mattress. Never a problem with the heater. (As long as you have some 110 power!)
Dec-22-2019 04:05 PM
Dec-22-2019 12:48 PM
Dec-22-2019 04:47 AM
JKJavelin wrote:
I'm only speaking from my experience. The electric blanket we use in the camper has a 'preheat' button which warms it up within about 10 minutes. The mattress pad takes a lot longer. I don't know if others have a preheat. Both work very well once warmed up.
Dec-21-2019 06:54 PM
Dec-21-2019 04:01 PM
Dec-21-2019 11:38 AM
JKJavelin wrote:JRscooby wrote:JKJavelin wrote:
. The only negative is it heats slower than an electric blanket.
This may or may not be true. And if true, may or may not be a issue. I know that in my truck, my camper, or house, it has never been a issue for me. AFAIK, the real difference is you use one over, the other under you. Somebody told me heat goes up.
Dec-21-2019 11:06 AM
Dec-21-2019 09:42 AM
Dec-21-2019 07:19 AM
Dec-21-2019 06:02 AM
Dec-21-2019 05:36 AM
Dec-21-2019 05:11 AM
rk911 wrote:
Considering adding a heated mattress pad to our IdealRest air bed in our Itasca Suncruiser. is anyone using one? any problems? can't imagine there would be any adverse issues using a heated mattress pad on an air mattress but thought i'd ask before pulling the trigger. any recommendations? looking at a dual-control model.
https://www.amazon.com/dp/B004P4CZLE/ref=cm_sw_r_em_tai_c_yHy.DbY24HDH5
Dec-21-2019 02:28 AM
Dec-21-2019 01:42 AM
