Leichardti
May 11, 2017Explorer
Help finding Short/Open loop in trailer brake system.
2004 WW fB200 Toyhauler
The trailer brake unit inside my truck is showing a short or open loop code. My friends truck says the same thing when I plug the trailer into his truck.
The +, ground and all the trailer lights work fine on the trailer.
When towing the truck looses and gains connectivity with the trailer randomly. Physically moving the plug, wire, etc doesn't alter anything.
Multi meter shows connectivity between the trailer brake wire (blue) and the turn signals, running lights, ground, etc.
I have traced the wires from the plug to the brakes and have not found any issues.
Could the issue be were the wire physically connect to the brakes?
Could the emergency brake unit be causing this issues?
Any info to finding the source of the problem would be great.
Thank you for your time.
