Jim_Cindy
May 21, 2013Explorer
Yellowing Slide Corners Solution
« on: April 01, 2012, 10:03:12 AM » Quote
The following is a post on the Carriage Forum about using a Sherwin Williams paint. Good Luck on your project. Let us know how it turns out.
----------------------------------------------------------------------The pieces that fit diagonally on our slide corners had started turning yellow, mainly, I guess because they aren't Gelcoated. A fellow RV'er some years ago told us about a paint that works wonders for that problem. We used it on the rim of our Cedar Creek door window and it stayed white for 5 years until last year when we traded for our Cameo. Just painted the pieces on our slides and now they match the Gelcoat of the Cameo. The paint is Sherwin Williams All Surface Enamel, Acrylic Latex High Gloss. We've noticed that every Carriage we've seen (without the full body paint) has the yellowing slide pieces. The paint goes on so well--I'm sure you'll be pleased with the results.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
