Trible_e's avatar
Trible_e
Help re towing on dolly
Anyone know if a 2013 Mercedes-Benze b250 turbo can be towed on a dolly.
It is not a 4matic. Any information will be appreciated.
Thank you
  • Everything I have read shows the automatics cannot be flat towed. If you have a manual transmission model, it can be flat towed but is not blessed by the company. I have not found any limits on FWD vehicles using a dolly, but some may be difficult if the steering locks and there is not a bypass.
    If you are set on towing this vehicle, you may have to use a trailer with all four wheels up to do so without damage.
  • Check the owners manual. It should have the info you want.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
