โJul-08-2013 02:13 PM
โJul-11-2013 08:19 PM
โJul-11-2013 04:01 PM
โJul-11-2013 03:23 PM
oxygen wrote:Do you travel with full propane tanks?
---Any advice on adding more weight to front of tv?
โJul-11-2013 08:25 AM
Ron Gratz wrote:
ASSUMING THE FOLLOWING VALUES ARE CORRECT:
truck by itself, no wdh attachd
front axle-3200# assuming 40# would be removed by extra "tongue weight" due to 100# WDH
gross tv-6340# assuming 100# would be added by the 100# WDH
rear axle-3140# assuming 140# would be added by extra "tongue weight" due to 100# WDH
truck hitched but bars NOT engaged
front axle- 2940
tt & tv- 12300
trailer -5360
rear axle-4000# using tt&tv = 12300
THE TRAILER WEIGHT WOULD BE: 12300-6340 = 5960#
That value seems rather low given the dry weight of 5840#.
Was the trailer essentially empty when you weighed it?
Ron
โJul-11-2013 07:17 AM
โJul-11-2013 05:47 AM
โJul-10-2013 09:16 PM
Ron Gratz wrote:oxygen wrote:Okay, that takes care of part of the problem. Your reported values need to be adjusted both for the missing WDH and for the 200# added for WD +dog. The adjusted values are shown in
12300 was the scale value, the 12500 was scale value + DW and heavy dog who were not present when weight.---red
truck by itself, no wdh attachd, i was sitting in truck with all 3 weight
front axle-32403200# assuming 40# removed by tongue weight
gross tv- 6040
rear axle- 3000,3140# assuming 140# added by tongue weight
front axle- 2940
tt & tv- 12300
trailer -5360
rear axle- 4200,4000# using tt&tv = 12300
truck hitch, wdh engaged
front axle- 3060
gross weigh- 12300
trailer- 5540
rear axle- 3900,3700# using tt&tv = 12300
WITH THESE CHANGES, THE NEW ANALYSIS IS:
The "adjusted" weights for TV only are
Front = 3240-40 = 3200#, Rear = 3000+140 = 3140#, TV GVW = 6340#.
For TV+TT w/ no WD, Front = 2940#, Rear = 4000#, TT axles = 5360#
The indicated tongue weight is (2940+4000)-(3200+3140) = 600#.
The indicated total TT weight is 12300-6340= 5960#.
The indicated tongue weight percentage = 600/5960 = 10%.
The indicated load removed from the front axle is 3200-2940 = 260#.
With a 600# TW, I would expect approximately 250# removed.
For TV+TT w/ WD, Front = 3060#, Rear = 3700#, TT axles = 5540#.
The indicated load added to the TT axles by WD is 5540-5360 = 180#.
The indicated load added to the TV's front axle by WD is 3060-2940 = 120#.
It is physically impossible for your rig to have 180# transferred to the TT axles, while having only 120# transferred to the TV's front axle.
The amount transferred to the front axle should be close to 340#.
The indicated load removed from the rear is 4000-3700 = 300#. The amount removed from the rear should be close to 520#.
After accounting for the WDH not being included in the "TV only" weights, the indicated tongue weight now is 600#.
However, there still is a significant discrepancy between the hitched with WD and hitched without WD values.
If you add 220# to the front hitched with WD value of 3060#, it becomes 3280#.
That then makes the calculated rear value 12300-3280-5540 = 3480#.
This would resolve the large discrepancy.
It looks to me as though about 220# was missing from the TV when the front axle hitched with WD applied measurement was made.
Ron
โJul-10-2013 09:01 PM
red
:3200# assuming 40# removed by tongue weight
โJul-10-2013 05:48 PM
โJul-10-2013 04:37 PM
Ron Gratz wrote:oxygen wrote:Okay, let's take the scale numbers and make an adjustment for the WDH which was not included in the "T only" values.
I just took scale weights, left the DW and dog out of the picture
We'll assume the WDH would remove 40# from the front axle and add 140# to the rear axle.
For TV+TT w/ no WD, Front = 2940#, Rear = 4200#, TT axles = 5360#
The indicated tongue weight is (2940+4200)-(3200+3140) = 800#.
The indicated total TT weight is 12500-6340= 6160#.i
The indicated tongue weight percentage = 800/6160 = 13%.
With an 800# TW, I would expect closer to 340# removed.
For TV+TT w/ WD, Front = 3060#, Rear = 3900#, TT axles = 5540#.
The indicated load removed from the rear is 4200-3900 = 300#.
After accounting for the WDH not being included in the "TV only" weights, the indicated tongue weight now is 800#.
However, based on what you've reported there, there still is a discrepancy between the expected load removal from the front axle.
And, there still is a significant discrepancy between the hitched with WD and hitched without WD values.
BTW -- your first post says the GCW is 12,500#. The latest post says the GCW is 12,300#. Which is correct? My analysis above assumes the GCW is 12,500#.
Ron
โJul-10-2013 04:02 PM
โJul-10-2013 07:40 AM
Ron Gratz wrote:oxygen wrote:Where did you add the 200# for DW + dog?
truck by itsef, no wdh attachd, i was sitting in truck with all 3 weight
front axle-3240
gross tv- 6040
fear axle- 3000, calculated from fist two
front axle- 2940
tt & tv- 12300
trailer -5360
rear axle- 4200, calculated
front axle- 3060
gross weigh- 12300
trailer- 5540
rear axle- 3900, calculated
โJul-10-2013 07:10 AM
front axle-3240
gross tv- 6040
front axle- 2940
tt & tv- 12300
trailer -5360
front axle- 3060
gross weigh- 12300
trailer- 5540
โJul-10-2013 07:02 AM
oxygen wrote:IMO, the WDH should be in the receiver and the bars should be in the WDH when all weighing is done.
1. is wdh to be attached when weighing only truck? I had it removed.
2. tt + tv, wdh not engaged, i left the bars hanging inhead socket..should they have been put into tt?It's best to leave the bars hanging in the sockets.
is wdhand bars considered part of tt or tv or combination of both when it comes to weight numbers?Strictly speaking -- the shank and ball mount should be considered part of the TV and the bars should be considered part of the TT.
