walleyeb1
Aug 05, 2013Explorer
Help with weight questions on tt
I am trying figure some of this weight information out. The link below is the same tt as mine.
This is the weight info below shows dw + ccc = 7,102. I thought it should add up to 7,790. The sticker on my tt has the ccc listed as 1,394, the gvwr sticker gives the same 7,790 figure. Why the discrepancy?
Next question is in regards to tongue weight, this show hitch weight as 790. Fully loaded the most our tt weight in at was 6,700. So I figured tongue weight as 6,700 x .14 = 938. Do I have this figured right?
Dry Weight 5,794 lbs.
Gross Vehicle Wt Rating (GVWR) 7,790 lbs.
Axle Weight 5,004 lbs.
Cargo Carrying Capacity (CCC) 1,308 lbs.
Hitch Weight 790 lbs.
Ratio: 14%
Thanks for the help.
http://www.roysrv.com/new_vehicle_detail.asp?veh=133633#detail
Ratio: 14%
