Hitch Adapter Sleeve
rrev
OK, So I'm using a Husky round bar hitch for my travel trailer and I'm pulling it with a 2008 Chevrolet 2500HD Duramax. I'm using the adapter sleeve with it and am noticing the the hole is starting to get a small amount of deformation around the hole. I've been told that this is common when having to use the sleeve because there is too much play with having two different gaps. I'm thinking of welding the sleeve to the stinger part of the hitch to eliminate one of the two gaps and some of the slop. Anyone else done this?
2008 Chevrolet Silverado 2500HD CCSB
2016 Starcraft Autumn Ridge 329BHU
2007 Starcraft Homestead 282DBS (Retired)
7 REPLIES 7
hbrady
I ended up going with new 2.5" Reese shank after reading a few hundred opinions ๐Ÿ˜‰
2015 RAM 2500 HD Crew Cab w/ 5.7L Gas
2018 SportTrek 290vik
Blue Ox SwayPro
mkirsch
Nomad II
Nomad II
My experience is the adapter sleeves are just too short. If you stick them in one way the sleeve hangs out the receiver by an inch and barely extend inside. If you stick them in the other way, they're an inch short of reaching the end of the receiver.
IMHO the adapter sleeve should be at least as long as the amount of shank that fits inside the receiver tube.
I've used Curt weldable receiver tubes for adapters with great success.
rhagfo
jerem0621 wrote:
a lot of people just go to a 2.5 inch shank and eliminate the sleeve all together.
Best option!
MudChucker
I made a pin buy turning a 7/8th bolt, still too much rattle...
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
Lynnmor
Just get the correct 2-1/2" shank and eliminate the rattles and possible bending of the pin.
To protect the receiver hole, get a pin with a shoulder, not the simple bent pin type. You can modify a bent pin like this:
MudChucker
I am in the process of making sleeves for all my existing hitches and plan to just burn them on ... I dont like the rattle...
2017 Cougar
jerem0621
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
