dockmasterdave
Sep 15, 2018Explorer
How cold is "too cold" ?
I'll start with the question first. How cold does it have to be or for how long, before I need to "winterize".
We live in extreme SWFL, it never really gets cold here. Maybe a couple days a year in a bad winter.
We have an Amerilite 21MBLE with no 4 season package, not even coroplast under belly. It is a moisture barrier then OSB set right on the frame, waste tanks are exposed.
All plumbing lines, I think, are run in the outside walls, fresh water tank and pump are under the bed.
We are thinking about hitting north FL or the pan handle this winter to experience some winter and look at some land.
I was thinking even low 20's would be OK if it warmed up during the day.
I know the waste tanks would take quite a while to freeze solid. How about the supply pipes ? I would fill the fresh water tank and disconnect my water hose, and run off the tank.
Also open to any tips or advice. TIA
