- bfast54ExplorerThe Easy way...is Have a a Professional Detailer, with YEARS OF EXP.
Buff it out,with the Special Compounds they have,then....keep it waxed.
Otherwise...you will wear your arms out,by hand...or,....burn thru,with power buffing,if you f
Dont do it Just right.....:W - ArticFox_676ExplorerWe really like Rejex products. Check out website.
- ninjagrosserExplorerThanks for the input, I appreciate it!
- harold1946ExplorerTR-3 Resin Glaze works quite well, or polishing compound. Both are available at most auto parts stores. Then use a sealer and wax, or skip thre sealer and wax and use aerospace 303 protectant.
- 1492ModeratorMoved from Forum Technical Support
- BumpyroadExplorerjust like you would a fiberglass boat
bumpy
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
