legolas
May 29, 2014Explorer
Francesca Knowles wrote:Nvr2loud wrote:oldchief7155 wrote:
Just turn it off when you fill your tow vehicle gasoline tank and then relight it when done fueling.
Except the reason is the possible ignition of gas fumes from the pumps, but turning the propane off will often still cause a source of ignition as each appliance attempts to relight. The spark rod is running causing a very high heat ignition source.
Propane off or on is the same risk.
I hope it's understood that when folks say "turn off when refueling" that means the appliances themselves, which then cannot relight automatically.
Hope springs eternal.............all you need to do is read some of the comments on this or any other topic and you find common sense in short supply...........There should be a requirement for an RV training class before allowing the masses to plunk down some cash and roar away with a TT attached or behind the wheel of an MH all without any idea of that they in essence have a tiger by the tail and it will bite, hopefully when it does I will be somewhere else. The same applies to operating a boat - motorcycle etc......I would love to see the same kind of training and testing required to obtain a private pilots license. Just to many scary folks on the highway with an RV......notice I didn't say IN CONTROL of an RV
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
