- deleted-2Explorer
slides wrote:
Thanks for the responses. This was just a messy job and I would just like to clean it up. Will the Klean-Strip harm the paint?
Probably.
If you do damage the paint Rustoleum white enamel can be brushed on.
It levels out pretty well and usually matches the polar white paint that is on most aluminum sided coaches.
Good luck there... - slidesExplorerThanks for the responses. This was just a messy job and I would just like to clean it up. Will the Klean-Strip harm the paint?
- wintersunExplorer IIWith Dicor any tool will work but with Proflex I have had to resort to metal tool and the one that has worked the best for me is an automotive gasket scraper.
Klean-Strip Industrial Maintenance Coating Thinner which is sold by Home Depot is excellent for cleanup and softening both the Proflex and the Dicor. - therinkExplorerIf it hasn't cured, mineral spirits works well. That stuff bonds very well once cured, which makes it a good product.
Once cured, I would use a razor blade lengthwise very carefully. - deleted-2Explorer...or a plastic type putty\scraper.
Sometimes I'd put painters tape on the edge of the scraper to keep from damaging the paint.
Don't use any type of distillate chemical like I tried.
Lesson learned there. - Go_Dawgs1ExplorerA putty knife. Go real slow and easy so as to not scratch the paint. I have also used a small flathead screw driver
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
