fvidania
Jun 09, 2014Explorer
How to Tow a 2002 Chevy Tracker (Suzuki Grand Vitara)
Hello,
I have a 2002 Chevy Tracker 4x4 manual transmission, same car than Suzuki Grand Vitara.
I have a blue ox base plate on it, a blue ox tow bar, safety cables, wiring..everything.
My problem is that I'm not sure how to set up the car before towing.
According to the owners manual:
"Follow these steps:
1. Set the parking brake.
2. Shift your automatic transmission into PARK (P),
or your manual transmission to SECOND (2).
3. With the ignition key in the ON position, move the
transfer case to NEUTRAL and make sure the
4WD light on the instrument panel cluster is off.
See “Four-Wheel Drive” in the Index.
4. Turn the ignition key to ACC to unlock the
steering wheel.
5. Release the parking brake."
Questions:
Manual transmission to Second?! how is that possible? wouldn't that stall the car?
Do I have to do this with the engine running or just with the key in on?
When I turn the key to ACC, do I release the clutch pedal before or after turning the key?
Give me answers, please and thank you!
steering wheel.
Questions:
Moved to Dinghy Towing forum from Towing.
