- rhagfoExplorer IIIGot to love our Dish Cube, place on floor in closet. In use we place on the 5ers roof!
- Thunder_MountaiExplorer IIWe put ours in the shower of our Outback TT.
- BumpyroadExplorer
PennyPA wrote:
My basement is completely full so there's no room under there. I, too, plan to fold the LNB arm up to the dish to make a smaller package. I guess it's onto the bed it goes.
Bumpyroad, you USED to carry it on your ladder; where do you carry it now or are you no longer on the road?
no ladder on my "new" TT. but I hung it upside down with the LNB? post on the RV side of the ladder with the dish on the outside of the ladder. no need to take anything apart.
bumpy - PennyPAExplorerMy basement is completely full so there's no room under there. I, too, plan to fold the LNB arm up to the dish to make a smaller package. I guess it's onto the bed it goes.
Bumpyroad, you USED to carry it on your ladder; where do you carry it now or are you no longer on the road? - hersheyExplorerI just sawed the LNB arm off and put a hinge on in so it now folds up into the dish. Makes all the difference in the world as for a compact package. I don't use a tripod, just a piece of pipe with a point that I drive into the ground and slip the dish onto it. Not much to store with that setup.
- Dutch_12078Explorer III modified my Dish 1000.4 hardware so it only takes a minute or two to separate the reflector from the arm and mount assembly. The two pieces store easily in a bin along with the collapsed tripod.
- BumpyroadExplorerI used to hang my dish on my ladder. hooked it over the step and used a large U shaped bike lock to padlock it on.
bumpy - imgoin4itExplorerI took a regular sat antenna and drilled out the rivets on the LNB arm and replaced them with regular bolts and wing nuts so that it will fold up. When is is "flattened" you have more storage options.
- nomad297ExplorerI bought a Folding LNB arm kit from www.tv4rv.com which makes the amount of space needed to store my dish minimal. It will fit into many storage compartments, also.
Bruce - DuckExplorer
buc1980 wrote:
I disassemble and I carry in the storage compartment.
X2 but front storage compartment
Don
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
