lightning60
Apr 08, 2017Explorer
DiskDoctr wrote:
Just a few mins, but this should get you started....
WDH- YES, definitely.
Sway control- yes, it will help, especially with that big wind catch from side winds (ie bridges, open fields, etc)
Inspect your vehicle's hitch and frame. Do it TWICE! If you're not sure, get a good mechanic to check it. What is the weight rating on the hitch, condition of frame, hitch, bolts?
Age has a tendency to be not-kind to steel. You'll be hooking over 5-1/2 TONS of weight behind you, make sure it is all ready for it.
Enjoy!
Thanks DiskDoctr! I just finished installing my brand new receiver hitch from Curt. It is rated for a trailer weight of 10000 lbs w/o and 12000 lbs with a weight distributing hitch. 1000 lbs tongue load w/o and 1200 lbs with weight distributing hitch. I inspected the frame and rear suspension, everything looks like it is in great shape. This van did not have a hitch installed on it previously.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
