- nevadanickExplorerCanadian tire has it as well.
- dapperdanExplorerHope it's not like what I found in Apache Junction this spring. I checked with 4 Walmarts in the general area and NONE of them had DEF. When I asked why two of them told me they were having troubles getting out of their DC, that and with the "great migration" of snow birds heading north all of the ones I checked at were cleaned out. I would think you'll have better luck in BC though.
Dan - Ron3rdExplorer III
996Pilot wrote:
Walmart SuperTech DEF $7.99 for 2.5 gallons. Fill up then carry an extra container with you.
Just looked -- Walmart in Dawson Creek, Walmart in Whitehourse, etc. You should be able to make it easily.
Every Wang Mart I have been to has DEF. I buy the Wang Mart brand too, no difference in brands. - whatimmadoboutmExplorer
missnmountains wrote:
DEF is not available at the pumps in Canada nor Alaska with one exception we found in Edmonton. You will need to purchase the jugs at Walmart or places like Tire Kingdom (Dawson Creek).
Ken
UFA in Alberta carries it at the pump. This may vary by location. - 996PilotExplorerWalmart SuperTech DEF $7.99 for 2.5 gallons. Fill up then carry an extra container with you.
Just looked -- Walmart in Dawson Creek, Walmart in Whitehourse, etc. You should be able to make it easily. - The_real_wild1ExplorerI have never had an issue finding def. I usually keep a jug in my igloo as well.
- missnmountainsExplorerDEF is not available at the pumps in Canada nor Alaska with one exception we found in Edmonton. You will need to purchase the jugs at Walmart or places like Tire Kingdom (Dawson Creek).
Ken - pigman1ExplorerDEF may be available in jugs at places, but I've been driving the Sweetgrass, MT to Alaska and return 7 times and have yet to find bulk DEF at the pump. Probably due to winter temps. Plan ahead. I have an extra 15 gal DEF tank on my Bus and fill at Shelby, MT, northbound and again southbound. I don't need to look for DEF in AK or Canada. Before I installed the tank I used to carry DEF in jugs in the basement. Big PITA.
- loggenrockExplorerWhat is your range between DEF fill-ups? I'm around 5000 miles from full to dash light on. Meaning - I could fill in NH and add in AK. If you are concerned, just leave with a full DEF tank...
- BC_ExplorerExplorerPretty much available everywhere in BC from major towns and cities to the multitudes of gas stations along the way. Cannot ever see finding DEF to be a problem.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
