Healeyman's avatar
Healeyman
Jump Statt Battery Pack
Hi All,
I wanted to use a LI Jump-Start Pack more as a battery power supply to power my in-car brake system, than as an engine starter.
My issue with the one I just bought is that the 12 VDC Power Port (cigarette lighter) output will not Turn ON and STAY hot unless the ON button is repeatedly pushed. It turns off after a few minutes.
The heavy battery cables will not become hot unless a small, residual, voltage is detected.
This (rather expennsive) unit won't light a bulb or spin a motor at all.
It seems to need to be able to sense some electrical power to enable the voltage outputs to energize.
Is this the way they ALL work?
Maybe I should just buy a LI battery and fabricate the needed charge & output cables.
Tim
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
