chiliman's avatar
chiliman
Locatioon to install Invisibrake in Honda Fit 2013
I have just purchased a 2013 Hiinda Fit Sport to tow behind our Motor Home.
I have also purchased a RoadMaster Invisibrake for toad braking.
My question is for those who have installed invisibrake in a Honda Fit.
Where did youu find the best place to put the master unit? It looks like under the driver seat is too cramped. I don't really want to take up the cargo area. I am afraid of damaging the unit while loading and unloading.
In advance I appreciate your input.
  • I'm having the same issue and I'm thinking of creating a platform to be above the Invisibrake where a passenger could rest their feet. I think it'd be the simplest solution. You could make it out of wood with little legs that are a bit longer than the height of the Invisibrake.
  • Ditto on the "no spare room" comment. Honda managed to turn all of the common "nooks and crannys" into usable cabin space. I installed the US Gear brake system and spent a lot of hours brainstorming where to put things. I ended up with the actuator servo immediately behind the outer driver seat rail. It intrudes into the rear passenger space a bit, but being on the side of the footwell, it's a nit. Ditto on the motorcycle battery observation, but still running the original battery in a 2009 model.
  • The Fit has no spare room,but other than that, it is a great toad. I ended up getting an RVi2 Braking system which, BTW, works great in the Fit. Also added a battery charging system since I swear, the Fit battery was taken from a motorcycle.
    You do have room under your front and rear seats. Under the front will compromise rear passenger leg/foot room and under the rear, it could hamper seat folding. You could always return the Invisabrake.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
