rv7plt
Jul 20, 2014Explorer
Low Braking Power
I have a 2002 Ford F250 with the factory installed tow package and a Prodigy P2 controller. I am pulling a 5th wheel Keystone Avalanche. I have minimal braking power on the trailer using the manual lever. At max deflection of the lever, the prodigy reads 12-13 volts output. I had the trailer wiring checked at a dealer and the brakes are pulling 12 amps as they are supposed to. Later, I decided to check the amp draw at the 7 pin connector. With the trailer connected, I cut the blue wire and connected an amp meter in series. I am only getting a draw of 5.9 amps with the prodigy showing 12 volts. Can anyone help with what I should look for?
John Henley
John Henley
