RV_daytrader's avatar
RV_daytrader
memory foam mattress in cold RV
I am going to replace the mattress in my class C and have to decide on memory foam or a high density regular foam....I camp in temperatures down to 25 degrees and do not use any heat when sleeping, so the inside temp can be 30 degrees by morning. Question is, will the memory foam warm up enough if I am in a sleeping bag to soften up or will it stay hard cause the sleeping bag is not letting enough heat reach the mattress?
