JimInMich's avatar
JimInMich
Mitsubishi Mirage, nice choice for a toad.
It would seem that a lot of people don't even know about the little Mitsubishi Mirage. Having owned one for 18 months, I love it! 2015 Mirage ES ( CVT trans ). Out the door price $15,200 ( includes tax/title/plates ). I have read on the Mirage forum that people have bought the 5 speed model ( base of $12,995 ) for $10,500 at some dealers ( with rebates ). The base model is not a stripped down version either. Plenty of nice features that are extra on other brands. This was my first import, having been a GM guys for years. It's not quiet like my DeVille was, there is hi-way wind noise. It's a little rough riding as well. But I didn't buy it for those features, I bought it for it's gas mileage and the warranty. Now that the engine is broke in, I regularly get 50+ mpg driving 55mph. If I get low 40's, I get po'ed :). Advertised MPG was 44 at hiway speed. Best feature of all is the warranty. 5 year/60k miles main warranty and 10y/100k drive train. That's more realistic for someone like ourselves, who don't put a lot of mileage on our vehicles.
If I knew then that I was going to buy a class A, I would have gotten the 5 speed. I checked, and you can flat tow the 5 speed. Curb weight of the 5sp is 2,018 lbs. If your looking for a light weight toad, check it out. If you don't mind a used vehicle, you can buy the 2014's ( and 2015's for that matter ) with low miles, very cheap.
  • I have a 2015 mirage se manual transmission. It has all the bells and whistles most people would want in a small car. Bought it new and had the Blue Ox base plate installed right away. We have driven it almost 100,000KM and flat towed it about 25,000KM over the last 9 years. We have had no problems whatsoever.  It’s so light it does not even increase my fuel milage and if I couldn’t see it in the rear camera I wouldn’t know I was towing it.  The car is great to drive and because Mitsubishi has discontinued manual transmission on all but the lowest end mirage, I am planning to keep it as long as I own my class A motorhome.
  • Gjac wrote:
    Jim, I don't see the Mitsubishi Mirage listed in the 2015 or 2016 dingy towing guide. Does your owners manual state otherwise?
    I was going by what the dealer service manager told me. I couldn't find the answer in the owners manual specifically, so i have an email to Mitsubishi support sent. I'm supposed to hear back within a couple days ( tomorrow? ).
  • austingta wrote:
    I know that years ago anything with a manual transmission was capable of being towed with the drive wheels on the ground. With today's advances in technology, is that no longer the case?
    Actually, that never was the case. As indicated, it depends on lubrication. Many (if not most) manual transmissions are splash lubricated. In some of them, that splashing is done by the "cluster gear". That gear only rotates when the engine is running. When the engine is not running with the clutch engaged, the output shaft bearing is not being lubricated. Oh, yes, it may go many miles without damage, but it will eventually fail.
    As always, the Owners Manual is the final authority. If it says NO to four down towing, it just might be prudent to believe it!
  • Gjac's avatar
    Gjac
  • j-d's avatar
    j-d
    YES that is no longer the case. It depends on the internal layout of the transmission. Some turn enough components when towed in neutral, to lube the transmission. Others don't.
  • I know that years ago anything with a manual transmission was capable of being towed with the drive wheels on the ground. With today's advances in technology, is that no longer the case?
  • No, I don't work for Mitsubishi. Just an owner who likes his gas sipper.
    And no, the CVT is not 4 down tow-able.
  • Your post sounds like you're a Mitsubishi dealer. :B
    The CVT in not towable four down, correct?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
