moving mounted tv
jk31668
I have a sunseeker 3100ss with the TV mounted on a swivel bar above the chair on the right side. can I move to the other side for better viewing by unplugging the coax cables and adding an cable extension to reach the other side?
1 REPLY 1
Hiking_Hunter
Yes.
If your coax connects to a wall plate with an antenna connector on it, just replace the short jumper with a longer coax (to keep from having to do a "mid-air" splice). RF cables with "F" connectors installed are generally available at Radio Shack, Wal-Mart and any electronics supply house.
You asked about "coax cables" (multiple). How many do you have?
Of course, you will have to have power at the new location also.
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
