rvgrammady's avatar
rvgrammady
Need braking system & tow bar
I am considering a very reliable 98 Saturn Wagon. It has a blue ox baseplate.
I have never had a toad before and want to start out small & cheap as I am not sure if towing is going to work for me or IF I will continue to do so. I'm a single gramma and will be doing this all by myself. I think I'm missing out on lots of stuff.. I usually rent at Enterprise as they pick me up.. but on last trip.. several places I had no rental and missed seeing lots.
OK I've looked/read everything on this forum and now I am totally confused.
The seller of the Saturn used a Blue Ox Alpha. I am going to find out if he used a braking system and if so what?
But for now... suggestions, pros/cons..
I know... sorry in advance this is gonna start one of those mouse wars. i need some advise...
Thanks for your help. Just in case it doesn't appear below..
'96 Allegro Bay 35' chevy gasser.. OK you Ford die-hards stop laughing..
    A very good choice given your concerns.
    Having a toad makes a world of a difference.
    Due to the many experts. Confusion is normal when you're trying something for the first time and using the forum.
    Highly recommend one. In some states it is required. Gas engine MH don't seem to have enough braking power when pulling a car behind IMO.
    Don't get all tied up with the flavor of the month on tow bars. For now if the car fits your needs find a tow bar that will hook up to the baseplates. Pull the car around and see what you think. If coming down a slight hill and hitting the brakes doesn't feel good, then get a mechanical brake system. Keep your eye on E-bay or Craigslist. I've seen used ones going for as low as $250. When you're done with it all, you can always resell easily.
  • Small is good when it comes to a tow car. But do get one. Even with a good tow bar setup it will probably be a hassle at times but SO worth it, in more ways than I can mention
  • X3 on Readybrake. We've had thousands of miles with it in all sorts of different terrain towing our CRV. Works great. Built in braking system is easy to hook up and is very functional.
  • X2 Readybrake Elite. It's brake and tow bar in one and you can get it with Blue Ox connectors to use on your current baseplate.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
