kfp673's avatar
kfp673
Aug 06, 2013
Need Electrical help
Hello All,
I brought my camper home (2006 Flagstaff) this past weekend and am running into an issue. I typically dont keep the camper at my house since I have a seasonal site but we have been bouncing around lately so its at home. Anyway, I wanted to keep some drinks in the refrigorator for next weekend so I figured I would use my 30 amp to 15amp adaptor to plug into my shed. The Shed is all GFI protected outlets and the minute I connect the camper it pops the GFI. It works perfectly fine without problem when hookd to a campground 30 amp service but I can seem to figure this out. The only electrical item in the trailer I know is bad is the electric hot water heater but I turn that off and turn off the breaker so I would think that is not causing the problem. I know I can run it on propane but my battery is old and I would prefer not to use the propane. As an FYI, even if every breaker in the camper is switched to off it still trips. Granted there are still some fuses that I have not pulled but as far as the breakers none of them seem to matter. Anything you can think of to help me make this work? Thanks
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 18, 2025
