LITEPHIL's avatar
LITEPHIL
Need more tongue weight
I have a 2002 Sandpiper T22 Lite and need to somehow add a couple of hundred pounds to the tongue weight somehow. Seems most everything is at the axles and back inside. Its a great little trailer but is a little unbalanced. The GVW is 6,200 and the tongue weight is only around 400 lbs loaded. My brother was a Forest River dealer and I have had many trailers and have found that the best handling trailers are at around 15% tongue weight.The truck and the hitch set up are not the problem,in fact I am using two friction sway controls and I have pulled this weight and size trailer before with no sway control and handled better then this setup. Truck is more than adequate for a 6,200 trailer. Problem is, all the tanks,bathroom,fridge,heavier mattress are at the rear. I have a pass through up front but it's not very big and I do have have my tools and heavier stuff in there but I am still light up front. Any ideas? I have dual tanks and a very heavy single battery up there. Can't fit 2 batteries.Thanks!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
