bsbeedub's avatar
bsbeedub
New 5er, fresh water
Our old TT had a gravity fed inlet for the fresh tank as well as a pressurized inlet for city water. While at my campsite, I was able to add water to the fresh tank from a six gallon jug into the gravity inlet if I needed more after the original fill up.
Our new 5er (five trips under our belt) has only one inlet that can be switched via valves for filling the fresh water tank or using city water. Pouring from a jug is now not an option. Obviously, I can’t add sanitizing bleach to the fresh tank with the old method either. I never realized this until I was talking with a tech at my dealership.
Regarding sanitation (I do this at home), the tech did tell me to pour the proper amount of bleach into my fresh water hose with a funnel then fill the tank normally from a water spigot. The pressurized water will then force the bleach from the hose into the tank. Different, but easy enough.
As for adding to the tank while at a campsite; is using a small pump the only option? Does a pump provide enough pressurization to work in this scenario? We are pretty good at conserving water and the most we stay at a site without water is four days but I want to be prepared to add water if I need it. I definitely don’t want to have to break camp to take the 5er to fill up.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
