TonySGA
Jan 25, 2021Explorer
New Keyless Jeeps
I am new to this Forum, Thanks in advance for some advice. I just brought home a 2021 Cherokee WITH the Active Drive 2 Power Transfer Unit for flat towing. However, even after reading the owner's manual I've got a question I was hoping some of you can answer. With my old Jeep Liberty, I had to be sure the key was left in the ON position while towing, so the steering column would not lock and I removed a battery cable as well. However, the new manual just says to push the starting button to OFF prior to towing it? Does the steering wheel on the keyless vehicles not lock as they did in all the keyed models? Also, I'll be using the Ready Break breaking system, and looking at the firewall in this newer Jeep, I'm not seeing much room to drill the required hole behind the brake pedal for the cable. Has anyone installed this themselves in a newer Jeep that can give me a pointer here also? Thanks!
