โJun-10-2021 10:23 AM
โJun-14-2021 10:46 AM
โJun-13-2021 08:18 PM
Draggo wrote:
Hello,
I recently upgraded to a 3/4 ton truck and it has the 2.5" receiver. I didn't want to mess around with the adapter so I picked up a Reese Titan shank however it doesn't fit correctly.
Please explain why it doesnโt fit correctly.
Doesnโt fit into the receiver?
Not long enough as you state below?
So my question is what are you using for a weight distributing hitch that has a 2.5" shank with about a 12" extension from the hitch pin to the holes for the WD head? I need the clearance so I can put the tailgate down when I'm hooked up.
Note that the longer the shank, the longer the lever arm on the receiver cross tube (a torque tube).
That would reduce the rating of the receiver and also increase the amount of WD bar travel required to do the same work a shorter shank would require
Thanks,
Mike
โJun-13-2021 07:44 PM
โJun-11-2021 01:48 PM
โJun-11-2021 10:14 AM
โJun-11-2021 05:54 AM
โJun-10-2021 10:22 PM
โJun-10-2021 07:41 PM
โJun-10-2021 02:31 PM
