Go_Dogs's avatar
Go_Dogs
New widow trying to winterize
Hi, recently widowed and trying to winterize TT for the first time.
Here's what I messed up: My HWT doesn't have a valve, so I had to remove the anode rod to drain it. Forgot to release pressure valve and almost got hit with a flying anode and drenched with nasty, mineral-laden water. I didn't have a 3/4 inch plug, so I snipped the remaining rod off the threaded end and put it back in.
So far, so not so good.
Then, I followed the arrows and directions to bypass the HWT, that my late husband had written on the water tubing, under the sink. My son helped with the pump and the hose. We ran the pink stuff thru the faucets/toilet and outside shower. Then I poured some down into the black/grey tanks and traps.
High five, right?
Wrong. Today I went to the hardware store and got a 3/4 inch plug to replace the anode rod. When I removed the rod, you guessed it. Pink stuff started gushing out. I hurried and put the plug in.
Apparently, I had not bypassed the HWT. No wonder it took so much antifreeze.
My question: Is it okay to leave the pink stuff in the HWT till spring or do I have to figure out how to really bypass and drain it?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
