Maybe your 31st year will be the charm ;). This from Nigeria 2120. One of many examples.
"As the aircraft was taxiing, the transfer of the load from the under-inflated No. 2 tire to the No. 1 tire on the same portside axle resulted "in overdeflection, over-heating and structural weakening of the No. 1 tyre."[1] "The No. 1 tyre failed very early on the take-off roll", followed almost immediately by the No. 2.[1] The latter stopped rotating "for reasons not established", and the subsequent friction of the wheel assembly with the runway generated sufficient heat to start a self-sustaining fire."
I never said a blown tire causes a fire (even though that is apparently exactly what happened in the above example). I said brake and tire fires happen quite often, and when the heat build up blows the fuse plugs, you don't want O2 blowing across red hot brakes, or brakes that are already on fire. You are right though...."explode" wasn't the correct term. "Let loose"? Although to a layperson I would argue that a
400psi fuse plug going would seem like an explosion.
Looks more than structural damage to me. Now when those
400psi fuse plugs go would you rather have non combustible nitrogen blow into that fire or air with oxygen that will accelerate the combustion?
http://profemery.info/aviation/A340_600_brake_test.jpg
Other reasons for nitrogen are less corrosion on the hubs, and moisture, and potentially a slower leak rate depending on the rubber compound among other factors.
Back to the main point N2 is generally a waste of money for trailer tires, unless you only have access to moisture laden service air or are doing high speed aborts from 150mph with your trailer.
