nbking wrote:
I have about a half tank of water in the water tank. I believe the hot water tank has been by-passed but I can't find where it is so far. Does the tank have to be completely full for the water pump to build up pressure?
I will check those items, again if I checked them before
Water heater valving would be on backside oof WH Tank inside the RV
Cold inlet and Bypass can be same valve (3-way 1/4 turn valve)
Water heater does have to fill up before pump can reach full pressure as WH tank has lots of air to displace (6,10 gal)
And a faucet needs to be open (hot/cold) to expel that air in system
Pumps can run dry just about forever.....doesn't need water as coolant cause no heat is generated. Diaphragm(s) only move 1/8"
