ocbms's avatar
ocbms
Norcold Refrig starts cooling and then stops
My 2010 Model 1201 Norcross started cooling then stops for some reason. You would start the refrigerator and watch the temperature of freezer go to 32 degrees F. come back the next day and find everything the 60's. I did it
  • The Norcol dianostic procudure is available to download as a PDF from their website. It will get you started. Be sure that the refrigerator is level. Mine was tilted by 4 degrees left to right facing the fridge and that was enough to cause it to shutdown after a matter of minutes.
  • What error codes?
    Is fridge level?
    Are you having problems on just one heat source....electric or propane or same problem on either?
    Is fridge in a slideout?
    How long does it run?
