LarryJM
Dec 01, 2011Explorer II
alpenliter wrote:LarryJM wrote:BarneyS wrote:
I have 5 gallons of Liquid Roof sitting in my truck and will be put on my roof just as soon as we get down to Florida.
Barney
What do you plan to do for the A/C since building up the roof around the A/C without removing the lower shroud and the entire A/C will create a pool type ridge around the A/C gasket that would be subject to pooling and possible leaks and the drain holes in the lower shroud are very close to the gasket as shown below.
Larry
Larry, that concerned me too, so I used the Liquid Roof and built a "dam" around the outside. So far no leaks. If I do find that it leaks, I will pull the AC and take the appropriate action.
Well then that would trap the condensate that is meant to drain onto the roof and off subjecting the A/C gasket to long term "submerged" conditions which I don't think it is designed for. It's good you haven't had issues, but I only mention this as if I were to do this I think I would seriously consider removing the A/C and then reinstalling with a new gasket after covering the roof. On trailers in the past, manufacturers would even mount extra roof support in support areas like the A/C and antenna to raise that area like 1/4" or even 1/8" above the surrounding roof to provide proper drainage away from the sealed area of the item.
The liquid rubber roof might no be thick enough for this issue to be much of a concern and I only mentioned this potential issue as something to at least consider and I'm sure Barney will make the right decision since he is knows what he is doing.
Each year when I do my annual roof debris removal I use a very thin flexible 18" plastic ruler to run up under the edge of the lower shroud to get whatever "stuff" has managed to find a home there and I'm amazed at the amount of "KRUD" that has established residence there. :p
Larry
Larry
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
