Nov-29-2011 03:46 PM
Apr-03-2020 10:52 PM
Apr-03-2020 10:34 PM
Jul-27-2018 11:13 AM
C Schomer wrote:Just for the record, Henry's website says specifically that the 287 elastomeric product is NOT recommended for RVs. (Henry's 887 Tropi-Cool Silicone is recommended for RVs including TPO "vinyl" roofs.)
I used Henry 287 SF almost 4 years ago. $65 for 5 gal. and it did 3 coats. I was just up there and except for the dust, it still looks like I just put it on. It's holding up better than the rubber ever did and it's soooo nice to have some texture when it's wet. No chalking or any bad signs, whatsoever. I blocked up the AC (left the wiring connected) so I could coat underneath a ways. Craig
Jun-14-2018 06:56 AM
DiskDoctr wrote:
Barney- How is your roof looking this year? It should have about a year on that new coating.
From what I am reading...the primer is for "challenging surfaces" whereas Liquid Roof does not need a primer for straight EPDM that doesn't already have another product on it.
Jun-13-2018 05:40 PM
Jun-26-2017 05:06 PM
Jun-26-2017 12:23 PM
Alpenliter wrote:
Why take the chance? Use Dicor Self leveling Lap Sealant for touching up the existing sealant. Good luck on your project!
Jun-25-2017 07:23 PM
Jun-25-2017 06:31 PM
sonora wrote:Gjac wrote:John&Joey wrote:This is my experience also. A friend bought a MH with a FG roof so he gave me a gallon of Kool Coat he had left over which is an acrylic like Heng's it looked good for about 3-4 years. I only had enough for 1 coat. I should have re coated it after 4 years but it is just getting to the point where I can see the primer and has worn off pretty evenly. I was going to re coat with Henry's Dura-White acrylic( has anyone tried Henry's). I coated it in 2006 so I think this extended the life of my roof for at least 11 years it may take another 5 years to completely wear off. But I think the right process is coat every 4 to 5 years to keep the roof white and prevent the top layer of EPDM from sloughing off. I have a friend with the same age roof that is completely black because he never coated it.
You know I saw when the thread was first posted and I said "what the heck?" Now I understand, thanks for your update. It has always been my opinion that liquid roof was overkill, now it also looks like it's not a 10-20 year fix either.
IMHO, you got a mess on your hands now. No way to fix that alligator roof without scrapping it off or replacing the whole thing. I paint my older 5'ver with that Heng's stuff. Lasts about 3-5 years then repeat. Not perfect, but seems to work.
Thanks for the update and the pictures. It really helps others when people do that. Two thumbs up.
I used Henry Tropicool 887HS. So far I am impressed.
May-31-2017 05:28 PM
May-28-2017 05:03 PM
May-28-2017 09:42 AM
May-28-2017 05:23 AM
May-27-2017 05:15 PM
John&Joey wrote:
Snip...
May-23-2017 07:34 PM
