rbcamping's avatar
rbcamping
portable washer and dryer with a twist.
I have been pondering installing a washer and dryer in my 5th wheel RV.
I have looked at the Splendides and others, most are quite expensive and have only fair to poor reviews.
So I have come up with a twist.
The closet is
65" high
24' wide
28" deep
If I install a dryer on a shelf on top and put in an inexpensive top loading portable washer underneath the space between them would be a few inches at best.
I plan on installing a pull out shelf on the floor with a safety pan and drain with the top loading portable washer on it. when its time to do laundry, I'll pull the washer out load it and start the laundry, I should be able to push the washer back in, let it do its thing and when done, pull it back out to unload and move cloths to dryer above.
I wanted to get peoples opinions and suggestions before doing the install. What do you think.
If you have any recommendations on brands, please share.
I figure the cost of this installation will come in around seven hundred and fifty to nine hundred depending on the machines.
Looking at a panda, costway, or Rovsun dryers and for the washer something like a RCA RPW210 WASHER, or a comfee, or panda.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
