โMay-06-2022 07:00 AM
โMay-14-2022 07:28 AM
DiploStrat wrote:StirCrazy wrote:
While I can appreciate the ability to do this I am still amazed at how much power people use when they are camping.. Maybe I am just the not normal one.
in my truck camper with the furnace running most of the time my AH consumption is about 35AH a day. in my 40 foot 5th wheel it is only up around 85 at 28 degrees F so running the furnace, letting the kids watch 1 movie a night and using my kureg in the morning and after supper and the odd microwave use.. popcorn... so your supper alone is almost my entire days use , but I am using propane not power, and same for my fridge and furnace..
I recently upgraded to LFP batteries in the camper, and I am still playing to see what I can do with it but my rough capacity is 9 to 10 times my daily use, as I use it a lot in the real early spring and late fall when there is or could be snow on the ground still and we get a lot of overcast days so I want to be able to go until the sun comes back out and can charge everything up again. I plan on switching the 5th over also , just watching for screaming sales again..
I guess my thought process is that by leaving the furnace, fridge, and stove on Propane, I can focus my power on the lights, furnace fan, pumps etc which maximizes the length of time I can go.. with the solar set up in the summer water and take capacity are my limiting factors now as I can go a couple months on the propane and I'll never run out of power with the solar panels..
Would be interesting to do an energy audit - am I using the same amount of energy, regardless of source. As my camper is considerably smaller than a fifth wheel, I suspect so. I am just using electricity as opposed to propane.
My objection to propane is mostly the challenge of finding the right adapters outside of the US, getting a certification that there is no propane left before shipping, compressor refrigerators tend to work better than absorption, and, finally, a 60 gallon diesel tank will produce more heat, longer than a common propane tank without the need to refill.
But if you never travel outside of the US, none of this may be worth it. Ironically, we have a gas stove at home. ๐
โMay-14-2022 05:33 AM
โMay-13-2022 01:28 PM
Sjm9911 wrote:
.... It almost seems if you had an answer in mind before you started the thread, labeling people as unaware of the options that are out there. A little disingenuous if you ask me.
โMay-10-2022 06:37 PM
DiploStrat wrote:
Two comments:
-- NEVER needed a generator. But my largest draw is the air conditioner and I can only do a short time before I would probably need shore power to replenish.
-- Would not consider electric heat. I use diesel. Diesel or gasoline are MUCH more energy dense than propane. (And using diesel or gasoline eliminates the need to carry multiple adapters for gas fittings in different countries.)
A number of new builds are using a heat exchanger for hot water. Water typically stays hot for two/three days after driving.
The systems on my truck are typical of expedition campers.
Two commercial examples are:
Aeon
Nimbl
โMay-10-2022 06:29 PM
โMay-10-2022 05:35 PM
toedtoes wrote:StirCrazy wrote:DiploStrat wrote:
Our current vehicle has 800Ah of lithium iron and 600w of solar. Of course, we also have a bigger, two door refrigerator.
Historic data: We budget 30 wall clock minutes of power per meal; 15 minutes of microwave and 15 minutes of induction cooktop. At a guesstimated consumption of 150A, this works out to about 75Ah for a dinner. With a two door refrigerator, fans/heat, lights, etc., we are usually down about 125 - 135Ah overnight.
Lithium iron allows a lot more power in less space/weight, but we did this for years with lead acid AGM.
While I can apreaceate the ability to do this I am still amazed at how much power people use when there camping.. Maybe I am just the not normal one.
I reciently upgraded to LFP batteries in the camper, and I am still playing to see what I can do with it but my rough capacity is 9 to 10 times my daily use, as I use it a lot in the real early spring and late fall when there is or could be snow on the ground still and we get a lot of overcast days so I want to be able to go untill the sun comes back out and can charge everything up again. I plan on switching the 5th over also , just watching for screaming sales again..
My electric use is even less. I don't run an onboard furnace - I use a Mr Heater and a small canister of propane to take off the chill the few times it's necessary. Electric only runs the water pump, a light or two for 30-60 minutes a day max, and recharging a phone/kindle when needed. I run out of fresh water long before I run out of battery (no solar) or propane.
โMay-09-2022 11:30 PM
K3WE wrote:
Very simple: Do you want, or need to camp with batteries/no electrical hookup?
Typical battery setups fall way way way short on heating, cooking and AC .
Being slightly more complicated: 20 and 30 Amp hookups also fall a little short sometimes...It can be done, but you'll have to stagger things.
โMay-09-2022 08:57 AM
toedtoes wrote:
...I run out of fresh water long before I run out of battery (no solar) or propane.
โMay-09-2022 08:54 AM
โMay-09-2022 08:53 AM
โMay-09-2022 08:45 AM
โMay-09-2022 08:34 AM
โMay-08-2022 02:17 PM
wa8yxm wrote:
there is a water heating system or two (Aqua-Hot for one) that uses diesel fuel to heat or uses engine heat... And you can use the hot water to heat cabin if you have enough of it.. (There used to be a residential water heater that did that in fact.. Hi-Point made in Marshall, MI.)
but I don't know anyone doing it.. I like propane for cooking, though I often use gas.
โMay-08-2022 02:06 PM
