- KountryguyExplorerLow and behold, out of the blue, they emailed me today offering to replace the defective hose. Probably will still change to a different system. Not sure what it will be. I have a metal hose support that the larger fittings will not fit in.
- C_SchomerExplorerI have several hoses and fittings that are about 13 years old and the female ends are shrinking so I ground down all the male fittings to make sure that they don't split those old shrunken ends
- Cummins12V98Explorer IIII quit using them several years ago when the coupling that slips over the fittings started cracking and would not hold the SH!T in.
They sent me replacements but the same thing happened.
Really not the best idea to have something rely on compression. - KountryguyExplorerI have tried several times to contact the manufacturer with no response. This will be my last purchase of their products. Zero customer service. As you can see, I have tried for over a year. I give up !!
- KountryguyExplorerI sent a message, but no response yet.
- ependydadExplorerIf it were me, I would give the manufacturer a call and see what they suggest.
- KountryguyExplorerI tried that, but maybe I had them too tight. They leaked.
- John_WayneExplorer III use them but if your worried about them coming off you can buy hose clams with a thumb screw fitting instead of the screwdriver fitting to tighten the connection that's what I do if I'm going to leave them hooked up for a long period of time
- ScottGNomadWow, never had one do that! Hope this isn't indicitive of their latest quality.
- KountryguyExplorerYes, the factory ends come off ! I also have used them for many years.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
