Guysakar
Jan 16, 2014Explorer
Price of amp hour based on generator recharge.
I am debating between different appliances, gadgets, etc... and am trying to figure how much each will cost to run off of the battery/generator recharging the battery.
Generator hours per gallon is obviously relative to generator model.
And charger amps is obviously model specific as well.
But is there a normal amount of time it would take charger X, to recharge a 120 AH battery bank, run down to the standard 50%, and brought back to 90%?
I am assuming a 60 amp (probably going with Progressive and wizard set up) charger will not simply throw 60 amps into the battery in a hour.
They (Progressive) say that the 60 amp will charge a 125 AH battery to 90% in 2-3 hours, but the state of the battery is not specified. Fully discharged?
I understand that climate, etc... effects this, but if a ballpark figure was out there, I think a lot of RVers and off the gridders would benefit.
