shaner82
May 31, 2016Explorer
Problem setting up my WDH
Tried to get the WDH setup for my trip starting tomorrow and I've ran into a bit of an issue. There's 8 chain links on my bars. Only the last two will fit. I would never be able to get the other chain links installed.
On the very last link, the bars are not level with the trailer tongue as you can see in the pic. Also, in this setup the rear of the truck sits 1" lower than normal, but the trailer is level
If I go to the 2nd last chain (the only other one I can get on), then the bars are parallel to the trailer tongue, the truck sits exactly the same height as normal, but the trailer is clearly not level (the front end is too high).
I don't know what to do at this point. Do the bars have to be parallel with the trailer tongue? If so, then my trailer won't be level.
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
