danewguy
Jun 26, 2013Explorer
problem with tow electric hook up on Georgie Boy
Hi all ,
I have a 2007 Georgie Boy Landau on a ford chassis, recently I purchased a new toad (jeep wrangler) and I have spent most of the day trying to get things set up. The jeep is all wired with a Cool Tech plug in wiring harness and before putting the connector (in front) on I wanted to make sure the wires are proper. I took a test light to the connector on my RV with the blinker on and I am not getting anything showing power in any of the pins. I crawled under the rig and traced the wires back to where they go into the main wiring harness and they look ok. I spoke to my local RV repair guy on the phone and he told me to check the fuse panels, from what I could see all the fuses were ok (there were like 5 that had to do with towing) I am really frustrated and losing my cool. Has anyone else experienced this? a 12 volt test light should light when placed on the pin correct?
Some one help please!!!!!!!!!!!!!
Moved to Dinghy Towing forum from Towing.
