Heybro's avatar
Heybro
Question about tires
I have been learning a lot about tongue weight and payload capacity lately, but I have not even looked into tire capacity and weight rating at all. I am going to need some help with this. So my truck has Goodyear 275/55R20 113T tires. It says the treadwear is 500, Traction B, Temperature B. It also says the max load is 2535 lbs, and max psi is 51.
My GAWR on my truck with those tires is 4000 lbs on the front, and 4150 lbs on the rear.
Ok, with that information, how do I figure out if I am good to tow a 7,000 lbs GVWR trailer, with 680 lbs of dry tongue weight without having a tire blowout? I heard something that you need D or E rated tires if you are going to tow. But it looks like my tires can handle 2535 lbs each, so shouldnt i be fine?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
