harmsal's avatar
harmsal
Question for the towing experts
Hi, my question is - what is easier to tow or would they tow the same: see below.
An all aluminum 20 foot flat bed trailer with dual axles that weighs 1400 pounds loaded with an 800 pound ATV and a 3500 pound SUV. Total weight - around 5700 pounds - give or take a little.
OR
a new Ford 4x4 pickup which weighs around 5500 pounds loaded with an 800 pound ATV. Total weight - around 6300 pounds - give or take a little.
Both have four wheels on the ground. Does it make any difference whether it is a pickup or trailer? This will be pulled by a Ford V-10 Class C.
  • A difference not mentioned so far is tongue weight - the flat tow will have no tongue weight while the trailer will have substantial tongue weight - probably 600 - 700 lbs if you can get the load balanced correctly, which may actually be quite hard to do. With a long Class C you usually have a very long tail behind the rear axle, which makes the effect of tongue weight quite high. While I prefer to tow a trailer for all the reasons given above, the tongue weight in this situation would make me favor the flat-towed truck.
    Brian
    OR
    Good morning. The trailer would be easier to tow overall for a few reasons in my opinion.
    1. The trailer can be backed up. The truck can not (unless you unhook it).
    2. The trailer would be easier to hook up although 4 down setups are not bad for hookup.
    3. Braking is easier to deal with on a trailer than on a 4 wheel set up.
    Make sure you are within your towing limits and make sure your class c can handle the tounge weight of your trailer.
    Good luck with the project.
  • The trailer would be easier but like the first poster said, your class C doesn't have the kind of capability (Doesn't mean you absolute can't but sure does mean you clearly shouldn't) and I don't think the Class C has that heavy of rated Hitch and may not have the chassis to support an aftermarket (This does mean you can't)
  • The trailer would have less rolling resistance, no drivetrain to spin.
  • Most likely neither....
    Your V10 Class C likely has only a 4K to 5K limit on it's towing capacity.
    Sorry.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
