Grit_dog's avatar
Grit_dog
Navigator III
Jul 27, 2019
Quick hitch receiver slop fix
Just towed the boat behind the camper which requires a hitch extension.
The slop from receiver to extension and extension to hitch results in the hitch dropping a couple inches and banging over bumps.
I tried a quick fix, shoved a fender washer under the shank in both connections.
Worked great and the washers didn't fall out after almost 1000miles of towing.
Sharing a free fix
  • ^That would guarantee the shim stayed in.
    Little noise doesn’t bother me cause I’m used to towing pintle hitches, but yes that’s a great suggestion.
  • Fun.
    Wonder if you couple that with a u-bolt fix if it would keep it from sagging and keep quite. I just have the u-bolt and love it, but it still sags, so maybe Ill try a shim.
    Also, check that your hitch is tighter on the ball. Put a loose ball in the trailer hitch, close and see how much play there is. Tighten the nut underneath to where it is snug, but not binding.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 01, 2026
