Eric91Z's avatar
Eric91Z
Rear end bouncing/Equal-i-zer 4-point 10K hitch
So, we finally got our first travel trailer - a Grand Design Imagine 2800BH. Just picked it up last weekend and took it right out for a shake down run. So far, pretty much everything ok. Biggest issue we are having is that it doesn't pull smoothly on the highway. Get a lot of oscillation type bouncing from the rear end.
Now, the roads are not great around where we have towed so far, but I don't think it should be pulling like this. Gets this small oscillation like bouncing from the back end. Doesn't really seem to affect the front end. Front end steering and feel is pretty much same as unloaded, but this back end gets going (not huge up down bouncing, but just constant oscillation).
Just trying to figure out what to try next to get rid of that. Here are numbers:
Tow Vehicle:
- 2016 Chevy Silverado 1500 4x4, crew cab, short box
- Truck weight with full tank of gas, my daughter and me in it: 5960 lbs
- Front tire pressure towing: 40 psi
- Rear tire pressure towing: 41-42 psi
Travel Trailer:
- 2017 Grand Design Imagine 2800BH
Measurements:
- Front: ground to fender lip, unloaded: 36.25"
- Front: ground to fender lip, loaded with WD bars on: 36.5"
- Front: ground to fender lip, loaded, no WD bars: don't have this measurement yet
Hitch setup: Equal-i-zer 4-point 10K
- Hitch head: has 4 washers in it
- L-brackets: mounted with 1 hole left at bottom
- WD bars install with slight up angle towards back - bars not completely level with a-frame
Weights:
- Just truck: 5960
Loaded (CAT scale numbers):
- Front Axle weight: 3320 lbs
- Drive Axle Weight: 3260 lbs
- Trailer weight (loaded for camping): 6080 lbs
- Combined Weight: 12,660
From that, tongue weight is right around 620 lbs. So just over 10% on tongue weight.
So, I have read and gotten opinions, but trying to figure out what to try or look at to get rid of the back end bounce. I have had some say need to increase tongue weight to around 12-14% (730 - 850 lbs). My question is, how do I increase that properly. We only have front pass through storage outside which is where most things are kept. Inside is just mostly items in kitchen area we loaded which is middle area of TT and little to nothing off back end. So not sure how else to re-load trailer for more tongue weight.
And what about adjustments to the hitch setup? Will adjusting the L-brackets for the bars help at all? Maybe drop brackets one hole to take a bit of load off the bars? We are getting zero sway and the other numbers look like we are setup good, so not sure if moving L-brackets will help or hurt. Input appreciated.
And what about tires. I know the stock "P" tires are not ideal for towing, but want to look at upgrading to LT tires as last resort given expenses and only 4600 miles on stock tires. Goodyear says max psi for these tires is 51 psi (Goodyear Wrangler SR-A ****). Would going to 44-45 psi, at least on the rears when towing, help at all?
And if there are good instructions or something out there to help understand the Equal-i-zer hitch setup and affects of changes, please point me towards it. The hitch owner manual doesn't help a whole lot. Would seem to be that if I drop the brackets one hole it will take a bit of WD out which means a little weight off the front and back to the rear axle. But none of that affects tongue weight still, correct? Just which axle it is distributing that weight to?
Any assistance or input appreciated.
Thanks,
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
