seatboard's avatar
seatboard
Rear lights (Brake, Turn .)
On our 06 revolution there are 10 lights on the rear of the RV, five on each side of the vehicle. Several are not working. My question is, are these lights made so that I will have to replace the whole fixture? Or can I break them apart and just replace the bulbs? on the ones which are burned out,I did break one of them apart but they were really stuck together at the seams. I replaced the bulbs but they are not as bright as the original ones.( Still, they are brighter than I am.:B
  • I did check the bulbs and they are the same but not what the manual calls for. I plan to get the right ones and try again. Yes, I did force them apart and they do come apart. They had a seal there and I am hoping They will seal back. Thanks for your input. I have been RV'N for about 8 years and still run into problems I havent seen or heard of. Thanks again.
  • Not sure about your make/model RV but some marker lights are designed to be accessed from the rear, i.e. inside the vehicle. Reach behind fixture, give the light bulb holder (not the entire fixture) a quarter turn and it will come out. Alternatively, it will be spring mounted, i.e. just give it a good yank.
    When you have to replace the bulb from the outside, the lens cover can get "glued" on due to wax, caulk and dirt. So it seems you are "breaking" it, but it is just stuck on there. Sometimes you will break it for real and have to replace the lens.
    If someone else has the same RV you have, they can probably give you better information. If not, post a closeup picture of the light fixture in question (with the lens off on the one you opened). That should enable someone here to give you information.
    If the bulb seems not as bright, verify you have the same bulbs. Did you check the part number on the bulbs and replace them with the same? You can have bulbs that look the same, but are not.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
