RobWNY's avatar
RobWNY
Reese Airborne Sidewinder and Skid Plate Lubrication
Can anyone tell me if I need to grease the skid plate on my hitch while using the Reese Sidewinder pin box? I know not to use a lube plate but even though the Pin won't be rotating, it will still slide in to position or out of position when hitching up and unhitching so common sense says I need to. If that's the case, can I use the Spray White Lithium Grease or should I use a traditional grease like what everyone used before the lube plates became popular? The dealer that's installing it told me to contact Reese for the correct procedure so I emailed them. They responded with instructions to call their towing tech support. When I called, I listened to a recorded message telling me to contact the dealer who installed the pin box. Uggh!
  • ACZL wrote:
    Rob,
    You said you cannot use one of those plastic plates/disks? There is another option you could try/use. As you mentioned, you could use reg grease or some type of spay lube or non dust attracting graphite. There is a company who markets are primarily semi drivers, but has gain a ton of users who are not semi drivers. Anyways it's called MotorKote. They have 2 products that will probly work for you. 1st is MotorKote Hyper Lubricant which is a friction reducer inside engines, BUT also HAS hundreds of other uses. 2nd is MotorKote 5th wheel grease. As name implies, it's for 5th wheels along w/ anything else that takes grease. FWIW, give them a call and explain what you want to achieve and for their recommendation. They are located in OH.
    Thanks for the info Mike. I'll give them a call. I see they have a website too. When I get a chance later today, I'll check it out!
  • Rob,
  • etrailer lube link.
    As with any hitch lube requirements always go to the hitch makers recommendations.
    Keep calling or emailing. Most mfg shut down on weekends anywayz.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 15, 2025
