Sort By
- noplace2Explorer
Turner, P wrote:
I happen to prefer the smell of WD 40 over Goof-off or Goo gone. Goof-off tends to irritate my nose and when it gets under my wedding band it burns the skin.
Have you considered divorce? :)
I've had the best luck with a razor blade and elbow grease. - dcmac214ExplorerAssuming it's tape facing and glue, you can loosen up the glue with a hair dryer and peel off the facing and some of the glue. Go after the rest of the glue with Goo Gone.
- Turner__PExplorerI happen to prefer the smell of WD 40 over Goof-off or Goo gone. Goof-off tends to irritate my nose and when it gets under my wedding band it burns the skin.
- Turner__PExplorerDynamite works but is messy so I use WD 40. Spray, wait a few seconds. Wipe residue with a rag. Repeat as necessary. WD will remove most price tag glue and most sticky stuff.
- FlatBrokeExplorer IICarefull with Goof off on any surface. I just spent time polishing the rear window in my Polaris RZR after using it to remove paint that was spattered on it. Started to eat it like acid. WD 40 is safer.
- sdianel_-acct_cExplorerGoo Gone x2
- Thunder_MountaiExplorer IIGoo Gone and lots of patience. You can use a syringe to inject it under the tape around the edges to get things started.
- JaxDadExplorer IIIGoof Off. Works great, won't affect most surfaces, won't leave the 'mechanics cologne' smell behind.
- Executive45Explorer IIIWD40...but try it in an out of the way space first. It shouldn't stain....Dennis
- 2oldmanExplorer IIGoogle: Remove sticky tape
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
