Repairing inside walls from water damage
trailvision
Been having an ongoing issue with a stubborn leak on The roof of our travel trailer. Think I've found the problem but I now have delamination (I think that's the term) of the walls. The walls have bubbled and I need to repair a section of about 1 foot wide by 3 feet. I should probably post pics but was wondering if anyone has had this happen to them (I'm sure it has) and can it be repaired by removing the covering from the plywood by heating the covering and gently scraping it away, replacing the wood and reinstalling the covering. Does this make sense? Any suggestions for a somewhat clean looking repair would be appreciated. Thanks
2005 Trail-Lite R-Vision TV-19QB
2007 Toyota Tundra SR5 Double Cab 5.7L V8 381HP 6 speed auto, tow pkg,
4:30 rear (just awesome)
7 REPLIES 7
trailvision
Thanks for the responses. Thought I could just strip away the covering but it looks like I might have to replace the damaged section. Thanks for the ideas. Doesn't look like I can get away with an easy fix.
Dick_B
Cover the damaged section with stick on shelf paper (for aesthetics) and camp in the rain a few times to be sure you fixed the leak.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
You cannot remove the "covering" on the paneling. It is bonded from the factory and impossible to remove without total destruction of it.
Best to find a new panel that is similar in color and texture or, as mentioned, find a contrasting color and use it as an accent.
Most of the time the paneling is glued and stapled to the studs. It is a bear to get off and you will wind up destroying the panel trying to remove it.
Been there done that.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
mark5w
Replace about 50% of my kitchen wall on my former Rv. Could not get a panel to match so I got a contrasting color and had to remove more panel in order for it to look right. Used top of the line contractors glue to glue on the new panels. It worked great, then I traded it in to get rid of it.
Good luck on your project.
'13 2018 JAYCO EAGLE HT FIFTH WHEEL | 30.5CKTS- '13 Ford F150 SCREW - PullRite Superslide - Roadmaster Active Suspension
Bob_Olallawa
If the paneling is the same in a closet, do the repair with the closet wall panel and replace it as close as you can.
Welcome to my home, that door you just broke down was there for your protection not mine.
trailvision
Yep, you're right. Will do.
WoodGlue
Posting a few pictures would help a lot!
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
